using GLC-SX-MM with SG220-26P
baselzind
Level 6
Level 6
can i use GLC-SX-MM with SG220-26P as I'm not able to find the official one MGBSX1-RF? will it cause future issues if i tested it and it work?
  The list of supported SFP is down below. I dont believe the SFP you mentioned will work but for sure will cause no problem if you plug and test. I tested many SFPs in different switches and what happen is it doesnt work and that all.
Supported SFP Modules
SKU
Media
Speed
Maximum distance
MGBSX1
Multimode fiber
1000 Mbps
550 m
MGBLX1
Single-mode fiber
1000 Mbps
10 km
MGBLH1
Single-mode fiber
1000 Mbps
40 km
MGBBX1
Single-mode fiber
1000 Mbps
40 km
MGBT1
UTP Category 5
marce1000
         - Supported ones can be found in this list : https://tmgmatrix.cisco.com/?npid=3406
 M.
like others said, this SFP not in compatible list.
recommendation is to use compatible SFP with switch given under @marce1000 link.
but practically i have uses GLC_SX_MMD with SMB series. you can try if you have SFP on hand, but cannot guarantee because officially its not in compatible list.
Good luck
KB
