01-29-2007 03:48 AM
Hi guys,
I have a customer that wants to connected 2 2Gb fibre channel sites together using the Cisco 15000.
I'm new to the ONS boxes.
Just got a quick Q. I've heard that you need a CTM to manage them (what is that?) but is there any other way?
Thanks.
01-29-2007 04:31 AM
Cisco Transport Manager (CTM) is a server based management plattform for bigger ONS networks. You don't need it for smaller networks. You can do everything with the CTC (Cisco Transport Controller). CTC is the management tool and locally stored in each ONS. You just need a browser.
I hope this helps. Please rate all posts.
Cheers
Rene
01-29-2007 05:55 AM
That was a big help.
So what would be the lowest spec ONS box I could use for the above scenario? I intend to manage them going over ADSL to a Cisco 877 then to the ONS box. So on that note, does it have an ethernet port?
Thanks.
02-02-2007 03:12 AM
Yes, it does have an Ethernet port located on TCC card (called front port) and also on backplane. Use of backplane port is recommended. TCC front port is more useful during on site debugging etc.
