Cisco SFP-10G-LRM module
bibi50bidault
Is the Cisco SFP-10G-LRM module compatible with OS3 fiber?
marce1000
 - You probably refer to OM3 which supports up to 100M , that should work as per https://tmgmatrix.cisco.com/?tpid=76
    max distance mentioned = 220M ,
 M.
TNOC
YES, Works on MMF and SMF 1310nm distance only 220m as RX sensitivity poor. OS3 Multimode fine. TNOC_0-1714060982461.png
