Hi, I need to know QSFP-40G-SR4-S & QSFP-100G-SR4-S have male or female MPO connectors?
hi all,going to be daisy chaining switches together, we got these QSFP moduleshttps://www.fs.com/uk/products/36157.htmlso we need female to female MPO leads (as the module is male), just dont know if we need polarity A or B or key up or key downthank...
What is different of GLC-FE-100FX-RGD V01 GLC-FE-100FX-RGD V02 and GLC-FE-100FX-RGD V03?Is there any offical documentation to explain it?I want to know what excatly item to each version.THX
I recently purchased two SFP-10G-SR SFP+ modules and I can't seem to get them to work at all in my WS-C3650-PD48-S I put the SFP into either 10 Gigabit port and I see this on the console: Jul 1 00:16:18.527: %PLATFORM_PM-6-MODULE_INSERTED: SFP mod...
Cisco SFP-10G-T-S Compatible 10GBASE-T SFP+ Copper RJ-45 30m Transceiver Module I cannot find Cisco part # anywhere
I've used Cisco LRM SFP's with MMF and SMF. today I noticed the c9200 supports the LRM SFP but is states MMF and not SMF. will SMF work with a c9200 and LRM SFP onver SMF?
Can someone once again explain to me the price difference between Cisco and generic SFPs? I had to quote both for a customer and it was $1100 vs. $35 in my currency
Hi, A customer is using a pair of 3560-x with C3KX-NM-10G modules. The connection between the two switches are Multimode OM1 and approx 140 meters. 10Gb is running with no problems. SFPs is SFP-10G-LRM. Now the customer is trying to replace the 3560-...
I have a new server with sfp intel E65689-005 that i need to connect to my C9410R with switch module C9400-LC-24XS . i need to know if the intel E65689-005 sfp is compatible with cisco SFP-10G-SR-S? the intel E65689-005 sfp specs are as below: -Suppo...
We have an old 15454 running 7.2.0 that is accessible only from an older Windows XP laptop running Java 1.4.2. Is there any way we can connect to this unit using a Windows 10 machine? I'm not having any luck Unfortunately, we won't be able to upgr...
I'm planning to design a DCI link with 32G/16G FC, 10 GE, 40GE clients. I will use NCS 1001 + 1002 (or 1004) shelves but I don't know if there is a Muxponder support 32G/16G FC clients. Please let me know about this. Thanks!
Hi, a dumb question i'm logged into the shelf remotly via CTC, I have the shelf view but cannot find how to open the menu
Does the ConnectX-6 Dx NIC card (QSFP28) auto negotiate down to 25G SFP28 for Cisco Switch #9500-48Y4C?Connection between the two devices would be through break-out LC cable. NVIDIA mentions that it won't work with this switch as they have not tested...
Is the Cisco SFP-10G-LRM module compatible with OS3 fiber?
I have a cisco sg350-10 switch with 2 sfp modules.Which brand suggestions would be compatible modules for a sfp rj45 connectors?can you send me the link of the manufacturer , brand or model suggestions?Any help would be appreciated.Thanks.
Subject | Author | Posted |
06-13-2025 07:42 AM | ||
02-03-2025 08:10 AM | ||
10-04-2024 12:50 PM | ||
09-24-2024 09:19 PM | ||
07-25-2024 01:25 PM |
