Connecting Meraki switches via fiber
eaglemite35
Hey Guys,
I have set up my Meraki switches in my server room to test my current environment and everything works flawlessly. When I hook up my Meraki switches to my existing environment one works and one doesn't. The only difference I can find is the connection that didn't work is connected via SFP+ uplink ports and the one that did work is connected via SFP uplink ports.
I have a MS350-48p-L3 switch with a MA-SFP-10GB-LR plugged into SFP+ uplink port to a MS125-24P switch MA-SFP-10GB-LR plugged into SFP+ uplink port via 9/125 single mode fiber. (This one didn't work when I connect it to my existing fiber cable)
The one that did work was a MS210-48FP switch with a MA-SFP-10GB-LR plugged into a SFP uplink port to a MS210-48FP switch with a MA-SFP-10GB-LR plugged into a SFP uplink port via 9/124 single mode fiber.
balaji.bandi
have you tested the one working with not working port ? have you checked patch cables ?
try no auto  negotiation ? what is the logs show in the switch.
BB
Tom Randstrom
If you swap the transceivers between the devices, does the issue follow?
Hello
The meraki compatiablity matrix states those sfp's are compatiible, Have you tried a direct connection between them, just to make sure the issue it isnt inpath?
Have you tried swaping the rx/tx endpoints around
Kind Regards
Paul
