Core Fiber????
Ibrahim Jamil
Level 6
Level 6
Hi Folks!
i m doing Some Project,okay so if I Want to connectec two switch to our CORE , in fiber cable how many core do i need?is it 4 core (2 each one Tx and one Rx)
is the multimode goes up to 550mtr
6 Replies 6
Tom Randstrom
Each link between switches will require two fibers (cores), one for transmit (Tx) and one for receive (Rx); two links would require 4 fibers (cores); unless WDM is used (another story).
Link distances varies by interface speed, fiber type and transceiver specifications.  For Gigabit Ethernet links, a 1000Base-SX transceiver module will support up to 1000 meters over OM3 or OM4 rated multimode fiber (MMF); less distance on OM1 & OM2 rated MMF.
Example distances can be found in the transceiver data sheets... GE SFP example below:
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/ps6577/product_data_sheet0900aecd8033f885.html
Additional fiber transceiver information can be found on the following document.
https://supportforums.cisco.com/docs/DOC-13721
Hi Tom
Exelent reply, can u help me from the Fiber Point of view , like SC,LC,Fiber Patch panel ,fiber Coupler, Type of Fiber Patch cord either for 1 gb , 10gb,40 gb, what type from the GLC-SX-SM TO THE coupler of thr fiber patch pannel i wanna use
I would recommend looking at one of Cisco's partners,
Panduit,<>as
they have the fiber interconnect products you are looking for. There
are
many equipment vendors... work with a trusted VAR or distributor Many of
your choices will depend on your network's layout/design as well as personal
preferences for fiber patching.
On Fri, Mar 4, 2011 at 4:42 PM, ibrahim.jamil <
Hi Tom
where to use LC/SC  ....LC/LC.........SC/SC fiber patch cord either for SM or MM ?
Ibrahim,
The decision on which connector to use will be based on the equipment's optical interfaces and your patch panel.  For equipment using pluggable optics, the following lists the connector styles used
Pluggable optics
SFP = LC style
XFP = LC style
GBIC = SC style
X2 = SC style
Xenpak = SC style
Patch panels may have either LC or SC style connectors and some will use MTP/MPO (multiple fiber cores per connector).
Your installation may require an LC on one end of the fiber jumper cable and SC on the other; or LC to LC or SC to SC, etc.. Each connector style can be ordered for either singlemode or multimode fiber.
The fiber type used in the network will depend on the links speed and length.  It is important to look to the future when installing backbone cables in hard to access areas, so you don't have to install new cables for future network needs.
I've attached a fiber design guide from Comm/Scope.  It contains a lot of information, but highlights some of the future planning.
I am not sure if I am answering your questions properly.
Good luck.
Tom
Thanks Tom
Your Answers are Extremly Powerfull and informative
