03-30-2014 03:42 AM
Two Small Questions:
1: Does the CPT-50 can works alone without CPT-600?
2: Does the CPT-50 and CPT-600 works in a Ring topology ?
Example: If we have 10 sites ( One Main HQ and One Disaster Recovery Site and 8 remote sites) that have a physical ring of fiber cable linking all of them). can we connect all the sites, one to adjacent to reach the HQ as a ring or we have to connect each site to HQ as Star topology over the fiber cables.
Can we use all the nodes as CPT-50 if the trafic is low?
Thanks for your support.
Solved! Go to Solution.
04-15-2014 09:38 AM
hello Ali,
haven't worked myself so don't know much in depth.
but here are few details.
CPT-50 can not work alone, but starting from software release 9.7, you can take one CPT-200 or CPT-600 and connect CPT-50.
if you have 10 nodes, than one can be a CPT-200 or CPT-600 connected with CPT-50 and than all other CPT-50 can be connected in a ring as standalone without CPT-200 or CPT-600.
so one CPT600 or CPT-200 connected with all other CPT-50 in a ring.
i know this above will work fine.
for more details we need to be in touch of a CPT expert.
all the best :-)
04-15-2014 09:38 AM
hello Ali,
all the best :-)
04-18-2014 10:42 PM
Thank You Supoonia for your clear answer, I hope a CPT Expert can confirm it.
Best Regards
