Determining Real-time Optical Power Loss using "show interface transceiver" command
ramal
Reading through the various topics here, I haven't seen this question directly addressed, so here goes.
For the sake of discussion, I have two Cisco switches, Switch1 and Switch2.  I  run the "show interface transceiver" command at both and get the following:
Switch1
Port
Optical
Tx Pwr
(dBm)
Optical
Rx Pwr
(dBm)
Switch2
Port
Optical
Tx Pwr
(dBm)
Optical
Rx Pwr
(dBm)
Te1/1/9
-1.3
-2.1
Te1/0/1
-1.9
-1.5
In this example, Switch1's Te1/1/9 is connected to Switch2's Te1/0/1.
Assuming the measured dBm values provided by each switch's SFP are accurate, can you calculate the real-time loss for the fiber link as follows:
Switch1->Switch2 Loss (dB) = Switch1 TxPwr - Switch2 RxPwr
   and
Switch2->Switch1 Loss (dB) = Switch2 TxPwr - Switch1 RxPwr
Of course, this results in a loss of < 0 for Switch1->Switch2.
So ... am I comparing apples to aardvarks here?
v/r
Joseph W. Doherty
Correct, i.e.: Loss (dB) = TxPwr dBM - Switch1 RxPwr dBM
"Of course, this results in a loss of < 0 for Switch1->Switch2."
Eh?
Sw1>Sw2: -1.3dBm - -1.5dBm = -.2dB
Sw2>Sw1: -1.9dBm - -2.1dBm = -.2dB
NB: actual subtractions' value is .2, but loss is always negative
Same loss in both directions - what one might expect, more or less.
Eh?
Sorry. I didn't have enough coffee when I wrote that. I have no idea what I was thinking at the time.
Anyway, I wanted to make sure that you could make reasonably accurate loss measurements (sans using an actual calibrated meter) using what the IOS provided.
Thanks!
