different type Optical Networking
leonardus_aditya
Community Member
Dear All,
i have question,can i do this:  "ws-c3560e-12D-E with X2 transceivers direct connect to uplink port (SFP+) on WS-C2960S-24TD-L " ?
At each link Fiber, can we use diffrent type of transceiver? (Example : X2 - SFP+ , GBIC - SFP)
Please give me info,
Thanks & Regards
3 Accepted Solutions
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
Not 100% certain what you're asking.  You can have different physical optical modules on the two ends of a link, e.g. SPF on one end, GBIC on the other, but they have to be compatible, e.g. SX to SX.  You also need to insure the optical modules are compatible with the actual fiber type and fiber length.
I concur with Joseph.  Just make sure the transceiver is compatible with your equipment and the transceiver is compatible with the fiber type, fiber link length and matches the transceiver type (SX, LX, etc.) at the other end of the link.  The below link is to a document that summarizes the location of some of Cisco's and other transciever information.
https://supportforums.cisco.com/docs/DOC-13721
Good luck!
Tom
The SFP type is designated by its receiving sensitivity. The interface is just the method for coupling. The only care we have to take is to put attenuators wherever necessary.
Joseph W. Doherty
Disclaimer
Posting
Good luck!
Tom
