speed negotiation settings for a 10G interface
tejasAtluri
HI,
We have the following setup:
2 ports of CISCO 6509(also has xfp long range)  switch connected to 2(XAUI) ports of SPARC box T5220.
When the SPARC box goes for a reboot, the link is UP at XAUI while ports are down at CISCO end.
However either of the following brings the link up.
. shut/no shut at 6509 or
. unplug and replug the cable.
No speed negotiation is configured at XAUI.
I would like to know if 10G CISCO 6509  by default has autonegotiation on?
From the document "Configuring and Troubleshooting Ethernet 10/100/1000Mb Half/Full Duplex Auto-Negotiation"
I found the following line
"By default, all devices are supposed to perform autonegotiation. 802.3z       does not specifically define a way to turn Autonegotiation off, for both       1GigabitEthernet and 10GigabitEthernet."
Im seeing the following situation:
"Assume that there are two devices, A and B. Assume that each device can       have Autonegotiation enabled, or disabled. The correct behaviour of link status       with autonegotiation in accordance to the IEEE Std 802.3z-1998 should be like       this:
  • If A is disabled and B is enabled, then A should report link up and B           should report link down."
Does it apply to 10 G inetrfaces also?
PFB the config output of CISCO 6509
Cisco IOS Software, s72033_rp Software (s72033_rp-IPBASEK9-M), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2)
cisco WS-C6509-E (R7000) processor (revision 1.5) with 983008K/65536K bytes of memory.
6  16  CEF720 16 port 10GE WS-X6716-10GE
6  Distributed Forwarding Card WS-F6700-DFC3C
interface TenGigabitEthernet1/6/16
description BKUP:SSCPRODENG-NXGE4
switchport
switchport access vlan 101
switchport mode access
spanning-tree portfast edge
end
NOLACORE#sh int te1/6/16
TenGigabitEthernet1/6/16 is up, line protocol is up (connected)
  Hardware is C6k 10000Mb 802.3, address is f866.f220.5027 (bia f866.f220.5027)
  Description: BKUP:SSCPRODENG-NXGE4
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 10Gb/s, media type is 10Gbase-LRM
  input flow-control is on, output flow-control is off
  Last input never, output 00:00:19, output hang never
  Last clearing of "show interface" counters 7w4d
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 81000 bits/sec, 7 packets/sec
     207547040601 packets input, 34173665463903 bytes, 0 no buffer
     Received 64391 broadcasts (0 multicasts)
     36 input errors, 36 CRC, 66 frame, 0 overrun, 0 ignored
     0 watchdog, 0 multicast, 0 pause input
     380437679022 packets output, 276421252994669 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
From the above config output can we say that 10Gb/s speed is forced on the link?
Tejaswi A.
0 Replies 0
