Does Cisco 9500 support FEC with 10GBASE-SR SFP module?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-12-2022 08:24 AM
Hello Experts,
I am using a Cisco 10GBASE-SR SFP+ module (10Gbit fiber) with a Cisco C9500-24Y4C-A switch. I want to enable FEC using this module. When I plug the module into a port the "fec" command in the "switch(config-if)" menu disappears. If I have no module plugged into the port, the "fec" command does appear.
Is FEC supported using the 10GBASE-SR module at 10Gbit/s?
- Labels:
Optical Networking
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-12-2022 09:25 AM
M.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-12-2022 09:32 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-12-2022 10:07 AM
- Consider using latest advisory release : https://software.cisco.com/download/home/286319595/type/282046477/release/Bengaluru-17.6.3 , if not yet done. Check if that can help.
M.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-12-2022 10:30 AM
what is the IOS XE code running, and what License you have : (can you provide below information)
show version
show license summary
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-12-2022 10:38 AM
Show version:
IOS XE 16.12.04
Show license summary:
Smart license enabled
License reservation enabled
Status: registered
Status: authorized
Usage: C9500 24Y4C NW Advantage
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-12-2022 10:56 AM
ok is this cisco SFP ? can you post below
show interface te x/x trans
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-12-2022 11:40 AM
RX power is -2.8dB
There is no "fec" command shown when I show help from the switch(config-if) prompt.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-12-2022 01:01 PM
i am more intrested to see the module - can you please provide :
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-13-2022 03:26 AM
"show interface twentyfivegige1/0/11 trans"
And then I get:
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
If device is externally calibrated, only calibrated values are printed.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
NA or N/A: not applicable, Tx: transmit, Rx: receive.
mA: milliamperes, dBm: decibels (milliwatts).
Optical Optical
Temperature Voltage Current Tx Power Rx Power
Port (Celsius) (Volts) (mA) (dBm) (dBm)
Twe1/0/11 28.2 3.33 8.7 -2.3 -40.0
Ignore the -40dB Rx power because the transceiver was not connected this time.
Do I have the correct command?
Here is "show idprom interface twentyfivegige1/0/11"
Description = SFP or SFP+ optics (type 3)
Transceiver Type: = SFP+ 10GBASE-SR (273)
Product Identifier (PID) = SFP-10G-SR
Vendor Revision = A
Serial Number (SN) = FIN2436016F
Vendor Name = CISCO-FINISAR
Vendor OUI (IEEE company ID) = 00.90.65 (36965)
CLEI code =
Cisco part number = 10-3035-01
Device State = Enabled.
Date code (yy/mm/dd) = 20/09/01
Connector type = LC.
Encoding = 64B/66B (6)
Nominal bitrate = (10300 Mbits/s)
Minimum bit rate as % of nominal bit rate = not specified
Maximum bit rate as % of nominal bit rate = not specified
Thanks You.
