DWDM SFP - log messages - should I be concerned
Joseph W. Doherty
Jul 21 18:52:36 UTC: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/1/4: Rx power high warning; Operating value:  -5.5 dBm, Threshold value:  -9.0 dBm.
Jul 21 19:02:36 UTC: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/1/4: Rx power high warning; Operating value:  -5.5 dBm, Threshold value:  -9.0 dBm.
Jul 21 19:12:37 UTC: %SFF8472-5-THRESHOLD_VIOLATION: Gi1/1/4: Rx power high warning; Operating value:  -5.5 dBm, Threshold value:  -9.0 dBm.
NB: platform:
WS-C3750X-48P      12.2(55)SE1
Tom Randstrom
-5.5 dB receive power is outside the target operating receive range, -9 to -28dBm, of the GE DWDM SFP.  Although it will not damage the sfp,  you may experience an increase in the bit errors.  You can install a 10dB attenuator (or attenuated patchcord) at the receiver end to bring the optical receive power within the operating parameters of the DWDM SFP.
Tom Randstrom
Hi Joseph,
I also had the same type of problem and refer Cisco TAC 629566213 for more details.
Here is the error message I got:
Mar 17 08:27:27: %SFF8472-5-THRESHOLD_VIOLATION: Te6/1/1: Tx power low alarm; Operating value: -40.0 dBm, Threshold value: -11.3 dBm.
Resolution was : Reset Interface hardware module
                           [switch <stack switch or switch number> frulink reloads
                           eg.  switch 6 frulink reload
Janaka Wellege
