Error-Correction FEC Arista - Cisco Interconnect
Netmart
Level 3
Level 3
I just want share my experience when setting up a connection between Cisco 25GB SR and Arista [100GB Breakout, 4x 25GB]
For both sites to be able to successfully negotiate the physical layer parameters the following is required.
Cisco works with auto [default] or cl174 while Arista needs to be set up as encoding fire-code.
Cisco
Arista
Options
cl74   cl91 Auto [default]
error-correction encoding fire-code
error-correction Reed-Solomon
Media
CISCO-FINISAR                       SFP-H25GB-SR
100GBASE-SR4 [breakout, 4x 25GB]
Cisco,  93180YC-EX
interface Ethernet1/47
description Arista-DCS-7508N  E8/21/3
  switchport monitor
  fec cl74
93180YC-EX # sh int ethernet 1/47
Ethernet1/47 is up
admin state is up, Dedicated Interface
  Hardware: 1000/10000/25000 Ethernet, address: 70df.2fe6.f4e8 (bia 70df.2fe6.f4e8)
 description Arista-DCS-7508N:  E8/21/3
  MTU 1500 bytes, BW 25000000 Kbit, DLY 10 usec
  Encapsulation ARPA, medium is broadcast
  Port mode is access
  full-duplex, 25 Gb/s, media type is 25G
  Beacon is turned off
  Auto-Negotiation is turned off, FEC mode is CL74
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned off
  Rate mode is dedicated
  Switchport monitor is on
  EtherType is 0x8100
Arista-DCS-7508N:
interface Ethernet8/21/3
   description  Cisco,  93180YC-EX,  E1/47
   switchport mode tap
   switchport tap default group mtnbox_nt0-AlwaysOn group mtsniff01_enp131s0f0-A
DCS-7508N#sh int ethernet 8/21/3 error-correction
Interface           Configured              Available                                              Operational
Ethernet8/21/3      Fire-code               Reed-Solomon, Fire-code                                Fire-code
sources:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/kb/b_Cisco_ACI_and_Forward_Error_Correction.html
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/transceiver-modules/implementation-optics-wp.html
0 Replies 0
