FIBER CONNECTION TO MANAGED SWITCH SMALL BUSINESS 300 SERIES
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-31-2022 01:38 PM
Hello Guys,
I'm just wondering if media convertors works with Cisco managed switches Small Business 300 series model.
I have a situation wherein I have a Pelco Based IP Based camera with PoE+ connection to a media convertor of Allied Telesis Brand PC series. Then, I have existing fiber optic cable in the location, where one end can be connected to this media convertor via SFP module and the other end to a fiber optic patch panel and onto the Cisco Managed switch.
I'm wondering if my above concept is right or wrong.
Please correct me if I'm wrong. Looking forward to your suggestions and comments!
Thank you in Advance!
- Labels:
Optical Networking
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-31-2022 01:51 PM
It seesm straightforward . This switch model has 2 Gigabit Ethernet combo and can use tihs SFPs:
Supported SFP modules |
SKU |
Media |
Speed |
Maximum Distance |
MFEFX1 |
Multimode fiber |
100 Mbps |
2 km |
MFELX1 |
Single-mode fiber |
100 Mbps |
10 km |
MFEBX1 |
Single-mode fiber |
100 Mbps |
20 km |
MGBBX1 |
Single-mode fiber |
1000 Mbps |
40 km |
MGBSX1 |
Multimode fiber |
1000 Mbps |
300 m |
MGBLH1 |
Single-mode fiber |
1000 Mbps |
40 km |
MGBLX1 |
Single-mode fiber |
1000 Mbps |
10 km |
MGBT1 |
UTP cat 5 |
1000 Mbps |
100 m |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-01-2022 06:35 AM
Thank you so much Miranda, for your reply and suggestion. So, its possible that media convertors can work with Cisco Managed Switches with the help of SFP modules, is that right? I believe that is the concept of connecting fiber optic cable between media convertor and managed switches.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-01-2022 07:04 AM
Yeah, I dont see any problem as long as you use the correct SFP and fiber on both sides.
I did it many time for different porpuses.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-01-2022 07:52 AM
Thank you Miranda! another question that just came into my mind is the usage of SFP's. Since the media convertor and the managed switch are of two different brands, does the SFP need to be the same on both ends?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-01-2022 08:20 AM
From the switch side you need to use any supported SFP. You can see those here on the datasheet:
Section: MFE and MGE Transceiver Ordering Information
Now, from the converter side, it depends.
Are you going to connect the switch directly to this media convertor of Allied Telesis Brand PC or will be some rack in between?
If the connection is direct, then, you are going to need a Multimode cable from the switch SFP up to the convertor Fiber port (Internal SFP).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-01-2022 08:43 AM
Yes, it is going to be a direct connection to the media convertor.
Thank you so much Miranda, for the solution!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
06-01-2022 09:09 AM
Any problem let me know.
