04-25-2017 01:08 PM
I have two different Cisco switches that need to be connected with optic fiber. The models are:
The fiber specs are:
My question is: what modules should I buy to connect the fiber to each switch? The datasheet states that for connection between two 2960x, I need GLC-BX-U= andGLC-BX-D=.
However, a vendor told me that since i have two different switches, i need a GLC-LH-SMD=, and a MBGLH1 for the SGE2010P.
What should i do?
Thank you,
Germán
Solved! Go to Solution.
04-25-2017 09:18 PM
The BX-U and BX-D types are SFPs for use in cases where you have only a single strand of singlemode fiber. They are not compatible with any GBIC that would go into the mini-GBIC form factor port at the SGE2010P end.
The vendor advised you correctly; assuming you have a pair of singlemode fiber and need to transmit over relatively long distance. Up to 10 km is supported for the GLC-LH-SMD= while the MGBLH1 supports up to 40 km - the lesser spec applies when interconnecting.
04-26-2017 03:01 AM
Obviously, the switch model is different, you can not use GLC-BX-U = and GLC-BX-D = module, and certainly can not connect with the other interface of the SGE2010P switch.
GLC-LH-SMD = and MBGLH1 is suitable for connection between these two Cisco switch.
By the way, the GLC-LH-SMD = is Available.
04-25-2017 09:18 PM
04-26-2017 03:01 AM
