03-28-2023 03:16 PM
Hello there, i am trying to simulate a connection of two routers cisco 2911 routers in packet tracer with optical fiber however i get an error message, " The cable cannot be connected to that port" , what could be the problem or procedure on using optical fiber connection between routers. Also when i add modules: HWIC-1GE-SFP on the 2911, they do not appear on the list of interfaces on the router. Help or hints will be appreciated on using fiber optics connection for routers.
Solved! Go to Solution.
03-28-2023 10:44 PM
Hello @Flavio Miranda thank you for your quick response,
I have found a solution, i managed to connect the two 2911 routers after adding modules HWIC-1GE-SFP and GLC-LH-SMD combined and i was able to connect. See image attached.
03-28-2023 04:15 PM
This router does not support fiber. Use an ISR4331 with module GLC-GE-100FX.
11-25-2023 01:58 AM - edited 11-25-2023 02:06 AM
Can you give a step on how to do it ?
03-28-2023 10:44 PM
07-01-2023 12:17 AM
These Above listed steps will help you to add the sfp fiber port connection
