Forced Full Duplex changes to Half Duplex (no mismatch errors)
f.korngut
Guys,
I am going through a very weird situation and wondered if any of you had any ideas on how I could troubleshoot this issue.
I am running a 2960 Cisco, which has a single mode fiber cable which is connected to multiple rstp switches designed by a mining technology company.
The fiber port which connects these switches has "duplex full" written into its configuration.  However, after a random amount of time, anywhere from 1 hour to 24 hours, the port is changes to operate in half duplex.  This is found by doing a show interfaces status.
At no time whatsoever is there any duplex mismatch errors.
Once i notice that the port is actually operating in half duplex mode, i log into the port, do a "duplex half"  then "duplex full".. the port goes back into full duplex for another 1-24 hour period.
Any ideas on why this port keeps jumping into half duplex operation?   I really need this port to run in full duplex and cannot understand why the port would go into half duplex operation when the end devices should support full duplex.
Again, i never get any duplex mismatch errors.
I appreciate any troubleshooting tips you can provide.
Vendor Name           :   CISCO-SUMITOMO
Well, son-of-a-gun.  I've never seen this vendor before.  Looks like your SFP is legit.
My next suggestion would be to upgrade your IOS to 12.2(55)SE2 or later.
11 Replies 11
Leo Laohoo
Can you post the following complete output please:
1.  sh version;
2.  sh cdp neighbor; and
3.  sh inventory
MSTswitchOVCC#sh version
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(53)SE2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 21-Apr-10 06:08 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01B00000
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
MSTswitchOVCC uptime is 1 week, 6 days, 37 minutes
System image file is "flash:/c2960s-universalk9-mz.122-53.SE2/c2960s-universalk9-mz.122-53.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960S-24TS-L (PowerPC) processor (revision B0) with 131072K bytes of memory.
Processor board ID FOC1435W6KX
Last reset from power-on
4 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : AC:A0:16:F3:EF:00
Motherboard assembly number     : 73-11910-06
Power supply part number        : 341-0328-01
Motherboard serial number       : FOC14354WTE
Power supply serial number      : LIT142210AX
Model revision number           : B0
Motherboard revision number     : A0
Model number                    : WS-C2960S-24TS-L
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC1435437G
System serial number            : FOC1435W6KX
Top Assembly Part Number        : 800-30954-02
Top Assembly Revision Number    : A0
Version ID                      : V02
CLEI Code Number                : COMGG00ARB
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C2960S-24TS-L   12.2(53)SE2           C2960S-UNIVERSALK9-M
Configuration register is 0xF
MSTswitchOVCC#
MSTswitchOVCC#sh cdp neighbor
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
MikroTik         Gig 1/0/22        110               R    MikroTik  bridge1
Centerville_POE  Gig 1/0/9         167             R S I  WS-C3560- Fas 0/3
MSTswitchOVCC#
PLEASE NOTE THAT PORTS 25-26 ARE THE ONLY PORTS THAT ARE AFFECTED.
MSTswitchOVCC#sh inventory
NAME: "1", DESCR: "WS-C2960S-24TS-L"
PID: WS-C2960S-24TS-L  , VID: V02  , SN: FOC1435W6KX
NAME: "GigabitEthernet1/0/25", DESCR: "100BaseLX-FE SFP"
PID:                     , VID:      , SN: AFL00352
NAME: "GigabitEthernet1/0/26", DESCR: "100BaseLX-FE SFP"
PID:                     , VID:      , SN: AFL00351
MSTswitchOVCC#
PLEASE NOTE THAT PORT 25-26 ARE THE ONLY PORTS THAT ARE AFFECTED.
What the ...?  I've never seen that syntax of a serial number.  Is that for real?
Can you post the output to the command:  "sh idprom interface Gi 1/0/25" (and 1/0/26) please?
Y'know if those SFP are NOT "Cisco" branded then that could be the reason for the issue.
MSTswitchOVCC#sh idprom int gi 1/0/25
General SFP Information
Identifier            :   0x03
Connector             :   0x07
Transceiver           :   0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Encoding              :   0x02
BR_Nominal            :   0x01
Vendor Part Number    :   GLC-FE-100LX
Vendor Revision       :   0x44 0x20 0x20 0x20
Vendor Serial Number  :   AFL00352
Other Information
Port asic num         : 00
Port asic port num    : 13
SFP presence index    : 00
SFP iter cnt          : 9752635
SFP failed oper flag  : 0x00000000
IIC error cnt         : 0
IIC error dsb cnt     : 0
IIC max sts cnt       : 5
Chk for link status   : 01
Link status           : 01
Autoneg enable        : 01
Flow control Pause    : 00
Flow control asymPause: 00
Duplex mode           : 00
PcsInfo               : 0x043F5C50
MacInfo               : 0x043F5C38 0x043F5C30
AutoNeg               : 0x043F5C30 0x043F5C38
SFF-8472 MSA EEPROM Data
000 :  03 04 07 00 00 00 00 00 00 00
010 :  00 02 01 00 0A 64 00 00 00 00
020 :  43 49 53 43 4F 2D 53 55 4D 49
030 :  54 4F 4D 4F 20 20 00 00 00 5F
040 :  47 4C 43 2D 46 45 2D 31 30 30
050 :  4C 58 20 20 20 20 44 20 20 20
060 :  05 1E 00 70 00 1A 00 00 41 46
070 :  4C 30 30 33 35 32 20 20 20 20
080 :  20 20 20 20 30 39 30 38 32 36
090 :  36 46 00 00 00 9C 2C 00 11 09
100 :  C1 85 49 B0 41 C3 43 79 A3 F2
110 :  F1 89 ED 50 AC 00 00 00 00 00
120 :  00 00 00 00 4F 3E BB B4
YETI INTERNAL REGS
Location=0xEF600500     :  Value=0x00
Location=0xEF600501     :  Value=0x00
Location=0xEF600502     :  Value=0x00
Location=0xEF600503     :  Value=0x00
Location=0xEF600504     :  Value=0x00
Location=0xEF600505     :  Value=0x00
Location=0xEF600506     :  Value=0x00
Location=0xEF600507     :  Value=0x02
Location=0xEF600508     :  Value=0x00
Location=0xEF600509     :  Value=0x40
Location=0xEF60050A     :  Value=0x00
Location=0xEF60050B     :  Value=0x00
Location=0xEF60050C     :  Value=0x09
Location=0xEF60050D     :  Value=0x00
Location=0xEF60050E     :  Value=0x01
Location=0xEF60050F     :  Value=0x00
Location=0xEF600510     :  Value=0x0F
yetiIICinited           :  Value=0x00000001
yetiIICLockPassCnt      :  Value=0
yetiIICLockFailCnt      :  Value=0
yetiIICLockApp          :  Value=35
MSTswitchOVCC#
Ok I downloaded the 12.2(58)....     I will try installing that.
I noticed that I could have grabbed a version 15?
What is the difference between 12 and 15 ?
Thanks so much for your help.
You want an "honest" answer or an answer?
I used to run the 15.0(1) IOS.  Take note I posted "used to".  I had to roll back to 12.2(55)SE2 because there's a bug with IOS 15.0(1).  The bug has a potential memory leak and is triggered when the switch boots up even without a config.
I've been telling people who read my post to stay away from the 15.0(1)SE IOS until Cisco fixes the bug.
This is my honest answer.
Marvin Rhoads
Given a Cisco switch with a genuinie Cisco transceiver running a relatively recent IOS such as you are, I'd suspect much more strongly that there is an interoperability problem with the "multiple rstp switches designed by a mining technology company". Are you able to contact the company that built them for technical support?
f.korngut
I am happy to report that this problem has been resolved by upgrading the cisco switch to 12.2-58SE2.
Thanks so much for everyone's ideas and help.
