GIG E Help
bolds04
Level 2
Level 2
I have a slight problem that I need some help on. We just ordered a GIG E connection from our bldg to our Co-Lo facility. The problem we are having is that when it was ordered by the engineer in charge of the project he thought that he could terminate it on a 3845 router. Well we were told by one of our Cisco SE's that in fact it will not work. So I am here trying to figure out what GBIC module we can use on our existing equipment to get this GIG E connection to work. Well at bldg "A" side we are going to use our new 3750 switches - model number WS-C3750-48PS-S. We have already purched the correct GBIC (LX/LH) for this side. I need to know if any of the equipment we have will accecpt a GIG E Gbic module.
Equipment we have:
CAT4506 w/ SUP IV (WS-X45-15) - NO MODULES AVAIL.
***Only have the 2 GBIC on the SUP Engine to use ****
couple 7206 routers
couple 7204 routers
If nothing will work on our existing equipment please let me know what you would recommend. I know that I could use another 3750 switch with layer 3 capabilities. Your help would be greatly appreciated. Thanks, Brandon
krestak
Community Member
3845 does not support Gbic, but SFP. To buy SFP is cheaper thaen another 3750 switch. Question is about traffic, I am not sure that on GigE port, 3845 is wire speed
Rene Frank
Level 5
Level 5
Yes, you can use your CAT4506 with Sup IV to terminate the WAN link. Just plug in GBIC LX/LH (Product code: WS-G5486) and configure an L3 interface on the GigE.
Config:
interface gig1/1
no switchport
ip address 1.1.1.1 255.255.255.0
I guess you have the standard image. so you can use static routing or RIP to route your WAN network.
