GLC-2BX-D activation
brijshah09
ASR 9000, A9K-MPA-32X1G, How to enable CSFP for this ? any command to run CSFP ?
marce1000
 - Install the necessary CSFP optics on the line card. This will typically involve installing CWDM SFPs (Small Form-factor Pluggables) in the appropriate SFP slots on the line card.
  1. Enable the CSFP feature on the line card by entering the following command in the CLI (Command Line Interface):
    router(config)# mpa type 10G-CWDM port <port-number> csfp
       Replace <port-number> with the number of the port you want to enable CSFP on.
  2. (Optional) Configure the wavelengths for the CSFP ports using the following command:
       router(config)# mpa type 10G-CWDM port <port-number> csfp wavelength <wavelength>
    Replace <port-number> with the number of the port you want to configure, and <wavelength> with the desired wavelength (in nanometers).
  3. (Optional) Configure the transceiver type for the CSFP ports using the following command:
     router(config)# mpa type 10G-CWDM port <port-number> csfp transceiver <transceiver-type>
  4. Save the configuration and reboot the router for the changes to take effect.
Hi @marce1000 , thank you for the reply.
Your suggestion for router(config)# mpa type 10G-CWDM port <port-number> csfp
refering to 10G CWDM SFP, can the same be applied for GLC-2BX-D which is a 1G , 2channel SFP.
Thanks in advance,
