can i use GLC-SX-MM with SG220-26P as I'm not able to find the official one MGBSX1-RF? will it cause future issues if i tested it and it work?
Hello all,I am trying to get a set up sheet for the 1.2G GS7000 nodes but the plant I work in is 750 and 860 MHz. The manual isn't all that helpful and math wise it's not adding up. Can someone contact me with a sheet of what RF hitting the receiver ...
we have just purchased two new SFP's "SFP-10G-ZR" so as to be used among 50 Km single mode fiber link but unfortunately the switch (3560CX-12PD-S ) did not recognize the SFP at all, when i issue show interface ten 1/0/1 it shows that it is not presen...
Hello everyone.I need help.I am trying to connect IE-9320-26S2C-E to C1000 series with SFP(GLC-SX-MMD or GLC-SX-MM-RGD).Looking for GLC-SX-MMD transceiver 1G, I can see the specification for transfer of distance to 1000m, however I can see the other ...
My team and I are trying to use send data via a transceiver we bought (the Cisco SFP-10G0SR Compatible 10GBASE-SR SFP+ 850nm Optical Transceiver Module). We are planning to use it on an FPGA board, but we don't know how to get started with it. Can an...
Dear community,today I received the SFP-10G-T-X transceiver for our Catalyst 9200L-48P-4X.I can't get an uplink.It seems the SFP+ tranceiver is not recognized by the switchA bit strange: an "Cisco compatible" 3rd party 10G transceiver is working.I up...
Hello,My NCS 540 (N540X-6Z18G-SYS-A) did not recognize a media non-cisco passive DAC 0.5m.Do you have some advices to resolve this problem ?And important, i can't buy a cisco DAC.
Hello everyone.I try to perform some tests with a SFP SFP-CH-OC3STM1-I on a ASR 920 with a Cisco IOS XE Software, Version 17.06.03. Marks it as not supported, *Feb 23 03:10:51.407: %TRANSCEIVER-6-INSERTED: C0/0: iomd: transceiver module inserted in G...
I am considering a C9606R for a solution. When it comes the line cards and interfaces I am looking at the C9600-LC-24C line card. When looking at the optics compatibility chart https://optics.cisco.com/?dr=7&dr=5&rh=18&npid=2223 I can see the vari...
Hi there,it's been a time i im with CLI oder http access to a cisco, so maybe u guys can help me out and have some patience with me, thanks !so whats going on ?I got a fiber connection from my ISP with EON fiber (germany) the UTM 9 firewall get the c...
Hi Team,I have a problem with compatibility between Cisco 2960 and GLC-FE-100FX. When I just installing the SFP, the port is err disabling.SWITCH_Y3_A#sh interface status errPort Name Status ReasonGi0/1 100FX err-disabled gbic-invalidAccording to com...
The initiative to move from catalyst to Meraki has started to happen due to cost and supply chain issues. in the Meraki switches you can get info about the sfp optic being used but can you get the transceiver detail info? When troubleshooting issues ...
What fields have to match between a server sfp and a switch sfp in order to determine they are both compatible? for example wave length , mmf...etc
Hello, We are considering buying the C9300-NM-2C network module card for our C9300X switch. The specs. on the data sheet doesn't' specify if this network module supports 10Gb port speed.I was wondering if anyone has and document that says that the ne...
Hello everyone, I need to password recovery for the cisco ONS 15305 R.3.0.The XTC board came from repair, the standard onscli password is not suitable.Cisco ONS 15305 End-of-Life Policy.Thanks in Advance.
Subject | Author | Posted |
11-12-2024 10:26 AM | ||
10-04-2024 12:50 PM | ||
09-24-2024 09:19 PM | ||
07-25-2024 01:25 PM | ||
05-05-2024 05:19 AM |
