GLC-BX-D/U SFP Compatible FOC
rcpmalana
I just want to ask if GLC-BX-D/U are compatible to all single mode fiber optic cables? Thank you.
Giuseppe Larosa
Hello @rcpmalana ,
for the way these specific optics work they one one laser in second window  (1310nm) and on other side one laser in third window (1550 nmm) they should work on every type of single mode fiber, for example there is no real advantage on using special fibers optimized for low dispersion in third window as one direction uses the second window.
Hope to help
Giuseppe
