GLC-BX-U
frankie_sky
Hi all,
Just wanted to clarify is this transceiver GLC-BX-U has patch cord of LC?
if yes, what are the model ?
Someone please assist , thank you
balaji.bandi
Not sure if i understand the question correctly,
You have SFP you can LC Fibre patch to connect - then yes you can LC patch cord.
here is more information
https://www.cisco.com/c/en/us/products/collateral/interfaces-modules/gigabit-ethernet-gbic-sfp-modules/datasheet-c78-366584.html
also fibre cable information :
https://en.wikipedia.org/wiki/Optical_fiber_connector
BB
Giuseppe Larosa
Hello @frankie_sky ,
the most  important info is that to build a working link you need:
one SFP GLC-BX-U on one side
one LC to LC fiber
one SFP GLC-BX-D on the other side
Because these special SFP use a form of DWDM with one type transmitting in second window 1310nm and receiving at 1490nm and the other type doing the opposite tx at 1490 nm and rx at 1310 nm
They are used to be able to use a single fiber cable instead of a pair of fibers like conventional SFP and SFP+ do.
Hope to help
Giuseppe
@Giuseppe Larosa  Good stuff, nicely covered ( i may not give more detailed, since i was in impression user aware of this)
Thank you again for your comment.
BB
