06-12-2020 12:06 AM
Hi all,
Just wanted to clarify is this transceiver GLC-BX-U has patch cord of LC?
if yes, what are the model ?
Someone please assist , thank you
06-12-2020 12:23 AM
Not sure if i understand the question correctly,
You have SFP you can LC Fibre patch to connect - then yes you can LC patch cord.
here is more information
also fibre cable information :
06-12-2020 12:55 AM
Hello @frankie_sky ,
the most important info is that to build a working link you need:
one SFP GLC-BX-U on one side
one LC to LC fiber
one SFP GLC-BX-D on the other side
Because these special SFP use a form of DWDM with one type transmitting in second window 1310nm and receiving at 1490nm and the other type doing the opposite tx at 1490 nm and rx at 1310 nm
They are used to be able to use a single fiber cable instead of a pair of fibers like conventional SFP and SFP+ do.
Hope to help
Giuseppe
06-12-2020 03:11 AM
@Giuseppe Larosa Good stuff, nicely covered ( i may not give more detailed, since i was in impression user aware of this)
Thank you again for your comment.
