07-20-2022 11:21 PM - edited 07-20-2022 11:22 PM
hi,
i'll be terminating a fiber cable to our ASR1K and use a GLC-LH-SMD SFP/GBIC.
just would like to confirm i need to use a SM fiber? can i also use MM fiber since the connection is "short distance"/same rack from fiber patch panel (SC from telco) and then LC to our ASR1K SFP.
do i use SC-LC SM or MM fiber or either will work? or is it best practice to use a compatible fiber patch cable with the SFP/GBIC? i.e. GLC-LH-SMD to only use with SC-LC SM fiber cable.
07-20-2022 11:45 PM
MM or MMD if the distance is <100 metres on OM1/OM2. <1000 metres on OM3/OM4 (1 Gbps only).
07-20-2022 11:50 PM
- FYI : https://tmgmatrix.cisco.com/?npid=1541
M.
07-21-2022 12:29 AM
i'm not asking if SFP is compatible with ASR1K.
i'm asking SFP to fiber cable compatibility here.
07-21-2022 01:24 AM
- Look at column Media
M.
07-21-2022 02:25 AM
hi,
so only SM fiber cable works on GLC-LH-SMD?
07-21-2022 05:58 AM
- Yes ,
M,
07-21-2022 09:14 AM
While sometimes you can get away with using multimode patch for a short length within an otherwise single mode end to end link, it is very much not recommended. The cost of a single mode patch cable is well under US$10 and well worth the headache avoidance.
Reference for my cost citation: https://www.fs.com/c/os2-9-125-single-mode-897
07-21-2022 05:22 PM
hi marvin,
thanks for your feedback! yes, i remembered i used a MM fiber on a SM SFP and it worked. that was a long time ago.
just asking here if it's best practice to stick with SM SFP with SM fiber patch cable.
07-21-2022 05:44 PM
It boils down to the distance. For 1 Gbps, <100 metres on OM1/OM2 or <1000 metres of OM3/OM4.
07-22-2022 05:40 AM
It's always best to match the fiber to the specification outlined for the optical transceiver. If you want to use multimode fiber for a short run, use the appropriate short reach (SX) transceivers on the ends of the links.
07-25-2022 08:29 PM
hi tom,
thanks for your feedback! will use proper SM fiber with SM SFP.
maybe i just got away using MM fiber with SM SFP
07-26-2022 05:57 AM
Sorry, I was not thinking straight regarding the question.
The GLC-LH-SMD is a 1000BASE-LX/LH transceiver, thus it is a SMF based module; but can also be used with MMF (with a launch cable). So it is possible that it what your previous experience was with mixed use SMF/MMF using the same transceiver.
