07-31-2018 03:14 PM
Our company bought several 40G to 10G adapters (part no.CVR-QSFP-SFP10G). I have experience with this type of adapter so I expected this device to be a passive feedthru device that allows me to configure and status the SFP+ module that I plugged into this adapter. However, the I2C status that I am seeing is the adapter itself, not the plugged in SFP+ module.
Is there a datasheet that describes the mapping of the I2C addresses that will allow me to use this device as a passthru? I am able to read the 256 bytes at the 0xA0 offset of this device and I am able to write some of these addresses.
07-31-2018 07:34 PM
What platform are you using the modules in?
Generally speaking there is a command (varies by platform) to tell the switch to recognize the inserted adapter as having multiple interfaces. for instance, on a Nexus 3k, there is the following:
Nexus 5k and 6k have the following:
...etc.
08-01-2018 06:55 AM
I am not using a Cisco platform to host the adapter, so I can't use the normal Cisco platform commands to access it. It seems like there should be a Cisco datasheet on the adapter itself that describes the I2C address mapping. Isn't this supposed to be a general purpose device that can be used with any other vendor's boards?
08-02-2018 01:12 AM
@grensink wrote:
...Isn't this supposed to be a general purpose device that can be used with any other vendor's boards?
No, it's not.
08-02-2018 06:52 AM
Thank you for the timely response. I will recommend to my company management that they look into returning these parts. And that they reconsider the purchase of other Cisco products.
