Installing Fiber Modules
dbrill001
We 2 Catalyst 3560-X switches and bought 2 C3KX-NM-10G devices with 4 SFP-10G-SR-S modules and they ran OM3 fiber which was tested. Why won't the fiber connections come up? What am I missing?
We have:
Ran a no shutdown
Put the modules in slots 2 and 4
Verified the Hardware is compatible
Please help...
Switch one end of the patch cord around.
8 Replies 8
Leo Laohoo
Post the complete output to the following commands:
1.  sh version;
2.  sh interface status; and
3.  sh inventory
Ok, I just saw that there is a limitation on OM3 fiber of 984 ft. Is there any way around that they tests they ran on the fiber are 1006 ft. I don't know how long the jumpers were they used but I am over by a few ft. Is there anyway around this other than cutting our about 10 ft on each side?
The distance is part degradation of signal and part loss of light power. The command I recommended will tell you your transmitted and received light power in dBm and let you know if that aspect is out of specification.
show int <your Te int #> transceiver detail
2103Catalyst#show int TE
2103Catalyst#show int TEnGigabitEthernet 1/1
TenGigabitEthernet1/1 is down, line protocol is down (notconnect)
  Hardware is Ten Gigabit Ethernet, address is d0d0.fde2.d29d (bia d0d0.fde2.d29d)
  MTU 1500 bytes, BW 10000 Kbit/sec, DLY 1000 usec,
  Keepalive not set
  Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-SR
  input flow-control is off, output flow-control is unsupported
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
2103Catalyst#
Show Version
2103Catalyst#sho ver
Cisco IOS Software, C3560E Software (C3560E-UNIVERSALK9-M), Version 15.2(1)E2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 11-Mar-14 20:03 by prod_rel_team
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560X-HBOOT-M) Version 12.2(53r)SE1, RELEASE SOFTWARE (fc1)
2103Catalyst uptime is 5 weeks, 2 days, 12 hours, 28 minutes
System restarted at 20:11:49 UTC Fri Aug 14 2015
System image file is "flash:/c3560e-universalk9-mz.152-1.E2/c3560e-universalk9-mz.152-1.E2.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3560X-24 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1427P14X
Last reset from power-on
9 Virtual Ethernet interfaces
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : D0:D0:FD:E2:D2:80
Motherboard assembly number     : 73-12554-04
Motherboard serial number       : FDO14280QA4
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3560X-24T-S
Daughterboard assembly number   : 800-32786-01
Daughterboard serial number     : FDO14270N92
System serial number            : FDO1427P14X
Top Assembly Part Number        : 800-31331-01
Top Assembly Revision Number    : A0
Version ID                      : V01
CLEI Code Number                : COMJU00ARA
Hardware Board Revision Number  : 0x02
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560X-24       15.2(1)E2             C3560E-UNIVERSALK9-M
Configuration register is 0xF
2103Catalyst#
Show Inventory
2103Catalyst#show inv
2103Catalyst#show inventory
NAME: "1", DESCR: "WS-C3560X-24"
PID: WS-C3560X-24T-S   , VID: V01  , SN: FDO1427P14X
NAME: "Power Supply 0", DESCR: "FRU Power Supply"
PID: C3KX-PWR-350WAC   , VID: V01L , SN: LIT14260265
NAME: "FRULink Slot 1 - FRULink Module", DESCR: "FRULink 10G ST Module"
PID: C3KX-NM-10G       , VID: V01  , SN: FDO190315W5
NAME: "TenGigabitEthernet1/1", DESCR: "SFP-10GBase-SR"
PID: SFP-10G-SR-S        , VID: V01  , SN: AVD1912D9L9
NAME: "TenGigabitEthernet1/2", DESCR: "SFP-10GBase-SR"
PID: SFP-10G-SR-S        , VID: V01  , SN: AVD1912D89A
2103Catalyst#
You left out the
transceiver detail
...bit in the command. That's required.
2103Catalyst#show interface status
Port      Name               Status       Vlan       Duplex  Speed Type
Gi0/1                        connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/2                        connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/3                        connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/4                        connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/5                        connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/6                        connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/7                        connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/8                        connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/9                        connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/10                       connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/11                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/12                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/13                       connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/14                       monitoring   1          a-full a-1000 10/100/1000BaseTX
Gi0/15                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/16                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/17                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/18                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/19                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/20                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/21                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/22                       connected    trunk      a-full a-1000 10/100/1000BaseTX
Gi0/23                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi0/24                       notconnect   1            auto   auto 10/100/1000BaseTX
Gi1/1                        err-disabled 1            auto   auto Not Present
Gi1/2                        notconnect   1            auto   auto Not Present
Gi1/3                        err-disabled 1            auto   auto Not Present
Gi1/4                        notconnect   1            auto   auto Not Present
Te1/1                        notconnect   1            full    10G SFP-10GBase-SR
Te1/2                        notconnect   1            full    10G SFP-10GBase-SR
Po1                          connected    trunk      a-full a-1000
Po2                          connected    trunk      a-full a-1000
Po3                          connected    trunk      a-full a-1000
Po4                          connected    trunk      a-full a-1000
Po5                          connected    trunk      a-full a-1000
Po6                          connected    trunk      a-full a-1000
Po7                          notconnect   unassigned   auto   auto
Fa0                          notconnect   routed       auto   auto 10/100BaseTX
2103Catalyst#
  Keepalive not set
2103Catalyst#
Marvin Rhoads
