07-09-2004 07:37 AM
At this URL:
http://cisco.com/en/US/products/hw/optical/ps2001/products_tech_note09186a00800fd533.shtml#info
There are instructions for launching 15327 CTC from the command line. I tried following them but ran into a problem. I am stuck at the step where I am supposed to download/ftp the files from a 15327 node and get the following files;
vbjorb.jar
launcher.jar
compat.jar
net.jar
ele15327.jar
if.jar
The problem is I dont have all of the files listed. I have several that have the same name but different extension of JGZ instead of JAR. Here is what I have in my 15327 node:
1419337 Jan-01-2098 16:07:58 COMPAT.JGZ
2619 Jan-01-2098 16:08:06 ELE15327.JAR
2322599 Jan-01-2098 16:09:00 ELE15327.JGZ
15176 Jan-01-2098 16:09:12 ETHER.DRV
325721 Jan-01-2098 16:09:26 ETHER.BIN
11920 Jan-01-2098 16:09:34 HDGE.DRV
407651 Jan-01-2098 16:09:50 HDGE.BIN
875975 Jan-01-2098 16:10:12 IF.JGZ
144511 Jan-01-2098 16:10:24 LAUNCHER.JAR
1960579 Jan-01-2098 16:11:06 NET.JGZ
11839 Jan-01-2098 16:11:14 OC12.DRV
224970 Jan-01-2098 16:11:26 OC12.BIN
22474 Jan-01-2098 16:11:34 OC48.DRV
217846 Jan-01-2098 16:11:46 OC48.BIN
33295 Jan-01-2098 16:11:54 OCNOCEAN.DRV
211018 Jan-01-2098 16:12:06 OCNOCEAN.BIN
1044 Jan-01-2098 16:12:14 RELEASE.HDR
3683172 Jan-01-2098 16:13:26 XTC.BIN
3 Jan-01-2098 16:13:34 EF3FB066.CRC
869656 Jan-01-2098 16:13:58 G850VXW
828959 Jan-01-2098 16:14:20 VBJORB.JGZ
2481775 Jan-01-2098 16:15:12 XTCVXW
Are the instructions wrong? It says that they apply to all 15327 software versions but this does not appear to be the case.
thanks in advance
07-15-2004 06:36 AM
Try to gunzip the jgz iles and rename them as *.jar files and see if it works. If that doesnot work, you might need to write some script which handles the jgz files automatically.
07-15-2004 09:33 AM
Thanks. I tried to gunzip those files and gunzip comes back and says not a valid extension. I have asked Cisco to review this document and comment on the problems I am having but not received a reply yet.
