I have a two part question. I am working on getting a IBM P520 running AIX 5.3.11 zoned into a MDS 9100. The HBA is a 2765(6228 FC). Last week we updated the firmware to the latest available for the card on IBM's website and changed the init_link setting to pt2pt. But still the link will not establish with the card. Has anyone seen this work in the past?
Also I have looked for an interapperabiltiy matrix for the 9100's and have not found one. Does anyone know where I could find one?
fcs2 U787A.001.DPM0R64-P1-C6-T1 FC Adapter
Part Number.................00P4494
EC Level....................A
Serial Number...............1E41107624
Manufacturer................001E
Customer Card ID Number.....2765
FRU Number.................. 00P4495
Network Address.............10000000C93D6AB8
ROS Level and ID............02C03933
Device Specific.(Z0)........2002606D
Device Specific.(Z1)........00000000
Device Specific.(Z2)........00000000
Device Specific.(Z3)........03000909
Device Specific.(Z4)........FF401113
Device Specific.(Z5)........02C03933
Device Specific.(Z6)........06433933
Device Specific.(Z7)........07433933
Device Specific.(Z8)........20000000C93D6AB8
Device Specific.(Z9)........CS3.90X3
Device Specific.(ZA)........C1D3.90X3
Device Specific.(ZB)........C2D3.90X3
Device Specific.(ZC)........00000000
Hardware Location Code......U787A.001.DPM0R64-P1-C6-T1
wbxpadm01: / # lsattr -El fcs2
bus_intr_lvl 147 Bus interrupt level False
bus_io_addr 0xbfc00 Bus I/O address False
bus_mem_addr 0xc0020000 Bus memory address False
init_link al INIT Link flags True (Changed to pt2pt)
intr_priority 3 Interrupt priority False
lg_term_dma 0x800000 Long term DMA True
max_xfer_size 0x100000 Maximum Transfer Size True
num_cmd_elems 200 Maximum number of COMMANDS to queue to the adapter True
pref_alpa 0x1 Preferred AL_PA True
sw_fc_class 2 FC Class for Fabric True
