Mr. Jagdeesh
Sub: Fiber patch cord specifiation.
Can any one let me know the right fiber patch cord specification for my newly installing coreswitch with 1G & 10 speed?
You may also name the some brand names.
Jag
Yes so you need multimode lc-lc om3 and I would go double shielded fibre for strength , unless your distances are really far apart then you may need some single mode , I use the 3 sfps at the bottom of your list there in my network and its all om3 lc-lc connections , your 10gb blades should be able to go 1gb and you shoul[d be able to use glc-sx for fibre or glc-ts for copper connections
Mark Malone
if its short distance use multi mode fibre OM3 LC - LC any generic brand
you haven't specified what 10gbs sfps your using so there could be other options too , are you using GLC-SX SFPS for the 1GB connections ?
Thank you Mr. Mark,
Further to this, my new coreswitch has both of 1G & 10G fiber line cards. And has 10GBASE-SR SFP LC Module modules and also  I will be using my old 1G SX SFF LC modules to connect my old field switches. My plan is to buy common patch cable to fit all these different modules/cards/speeds.
My assumption is all 10G compatible cable will also support 1G modules. Secondly 1G SX LC module will also work in 10G card.
By the way my switch specification is as below;
WS-C4506-E
S45EUK9-S8-38E
C4K-SLOT-CVR-E
C4500E-IP-ES
WS-X45-SUP8-E
WS-X4712-SFP+E
WS-X4724-SFP-E=
PWR-C45-1400AC
PWR-C45-1400AC/2
CAB-CEE77-C19-EU
SFP-10G-SR-S=
GLC-SX-MMD
SFP-10G-SR-S=
