03-18-2019 04:15 AM
HI All,
I am Planing to implement AVAYA IP PABX systems with 100 phones. Please advice me which Poe switches recommended for this network. Please note that DATA network already separated with different LAN network.
I will run only PABX network with this switches .All phones are POe.
Thanks.
03-18-2019 04:20 AM - edited 03-18-2019 04:21 AM
2960S or 2960X.
NOTE: I deliberately did not put Catalyst 9K.
03-18-2019 04:45 AM
03-18-2019 05:50 AM
Nothing wrong with Cat9200, Since you have mentioned only Voice and PoE, that is reason recomended for the low cost Switches.
03-18-2019 06:10 AM
03-18-2019 06:53 AM
they are small medium business, but they should work as expected, But check the specification and your requirement before you creating BoM.
