Nexus 9336C-FX2 SFP28 and QSFP28 question
patoberli
Hi all
We are in the process of buying new servers, the old ones were all 10 Gbps.
We have some 9336c-FX2 switches, which have QSFP28 ports.
The servers should be attached with 25 Gbps and reside in a different rack in a different row.
What is the best way to do that? I saw some third party QSFP28 to SFP28 adapters, would those work?
I like to avoid breakout cables if possible and a transmission over fiber is preferable. I don't care if I "loose" 3x 25 Gbps per port, if that means I don't need breakout cables.
Edit: they currently run in NX mode, in the future maybe in the ACI, but that's not defined yet.
Thanks for hints
Patrick
0 Replies 0
