Nexus 9k and Catalyst 9500 - Third party SFP support
darren-oconnor
Hey All,
We're spinning up a couple of Nexus 9k's and Cat 9500's for a short term piece of remedial work before a wider network refresh.  Due to budget constraints we need to keep costs down so we're exploring using third party sfp's to achieve this.  I appreciate that Cisco won't support us should we go down this route but has anyone experience with doing this?  We're looking specifically at FS.com (10G-LR and some QSFP-40G-LR)
Thanks all
Leo Laohoo
We have been using 3rd party optics for more than 7 years.  We have bought so much the distributor even gave us several "re-flasher" units for free.
And it is neither wrong nor illegal using 3rd party optics with Cisco equipment.
I have come across multiple Cisco Bug IDs that were (forcefully) generated by several Cisco "big whales" after using 3rd party optics.
It is also a well-known & well-accepted practice to buy a few genuine Cisco optics in case TAC will accuse the 3rd party optics for being at fault.
6 Replies 6
marce1000
  - You may for instance read https://www.cisco.com/c/en/us/td/docs/routers/access/1100/software/configuration/xe-16-12/cisco_1100_series_swcfg_xe_16_12_x/config-third-party-sfps.html#task_h4j_kfq_be
                (it applies to another platform but the commands mentioned could apply)
   Yet I advise against it  ; if we look at the cost of these boxes relative to the cost of  a cisco SFP and business importance,
   I would go for Cisco supported SFP's according to Cisco Optics-to-Device Compatibility Matrix
  M.
hi @marce1000 - appreciate the response and agree that using supported sfp's should be the correct way forward.  However, when faced with procuring £70k's worth of sfp's compared to £2k....money talks.  We already own the nexus and catalyst's so those assets have already depreciated so no additional costs incurred there.
   - Ok , but when used than at least you must test the intended links , before taking a (production) connection for granted!
  M.
Joseph W. Doherty
I believe @Leo Laohoo has experience using non Cisco optics.  Perhaps he might comment.
Leo Laohoo
Appreciate the response @Leo Laohoo
We've gone down the line of using a mix of genuine Cisco and 3rd party optics.  So far....so good
