No connection for POS over DWDM
hashaari
Hi!
I am currently doing some testing to connect 2 GSR with POS interface via DWDM using 2 ONS 15540 ESPx. The physical setup and configuration for both ONS are as follows
Slot 0 -> MMMB OADM Band AB with OSC
Slot 2 -> LCMB non splitter with TSP channel 1
Trunk fiber (6m) connecting wdm interface attenuated at 15 dB
Both TSP client side encap to sonet oc48 with monitor enable also on POS oc48 port at GSR.
The config and show output attached with this email.
The problem is that I couldn't get the GSR to connect. Isolation via loopback at TSP client side confirm that the TSP is OK. Only that wave and wavepatch interface keep giving me loss of light. Need you guys expert help and opinion to sort this out. Apreciate your prompt response. Thanks
Rgds
Helme
didyap
Level 6
Level 6
Wasn't able to go through the entire configuration but do you have the pos delay triggers line command enabled?
This command is used to trigger link down on path alarms.
