No LINK on port of Nexus5548UP
pslavkovsky
I have SFP-LH-SM in eth1/1 in Nexus5548UP but I have problem to get LINK on eth1/1.
I have SFP-LH-SM in eth1/1 in another Nexus5548P and it is not  problem to get LINK with same configuration of eth1/1
Is there some special setting for Nexus5548UP?
Is there diferent settings on interface on Nexus5548UP and Nexus5548P ?
Peter
Marvin Rhoads
The -UP model could have ports designated as Fibre Channel which would make the SFP-LH-SM an invalid transceiver for a port defined thus.
Can you provide output of the commands "show interface Eth1/1" and "show interface Eth1/1 transceiver detail" from the problem device?
Oleksandr Nesterov
Can you please try to set speed on the port and then insert the SFP module.
HTH,
Alex
