OC3x8 cards in Rel 6.0
bmyers
I am using the OC3x8 cards at Rel 6 in the 15454. I get High Rx power alarm when I connect an OC3 regardless of the actual Rx level. I have also changed the thresholds to no avail. Is there a way to clear this alarm without changing the alarm profile to not report?
Rene Frank
There is a field notice about your problem. You should check the serial number with the ones in the field notice and very likely replace the card. There is no workaround.
Here is the field notice:
Field Notice: FN - 62117 - 15454-OC3-8 and 15454E-S1.1-8 Miscalibrated Optical Performance Manufacturing Data
http://www.cisco.com/en/US/products/hw/optical/ps2006/products_field_notice09186a008052c129.shtml
