Optical Netwokring Certificate
omar_ccna
I just started preparing for CCNA(Switching and Routing)as the first step for me in the Networking Industry.Any one has an idea about that Optical Specialist Certificate from Cisco?
the I have found it as "Retired"
http://www.cisco.com/web/learning/le3/le2/le41/le82/le51/learning_certification_type_home_extra_level.html
is there any alternative from other vendors?
5 Replies 5
Michael Dooley
I don't know if there will be a CCNA version for optical (yet) but there is a CCIE Service Provider which is half routing and switching and half optical.
Mike Dooley
Cisco Optical TAC
Hi Mike,
thanks for the info,what I meant was a dedicated certificate (other than CCNA) for optical specialists...I found that SP Optical #350-020 is used for recertification (after CCIE)
but still i do not have CCNA yet ,so maybe this is not an option...although that am familar with the optical part(SONET/SDH,DWDM...etc)
Omar,
Yeah after I left the message I went and looked at the other Optical stuff. Looks like there's nothing really left, especially since the SP Optical is only good for CCIE re-cert. Strange...
Mike
Mike,
but you have given me a good info ...actually,now I know the syllabus for the optical stuff
http://www.cisco.com/web/learning/le3/ccie/sp/optical_blueprint.html')">http://www.cisco.com/web/learning/le3/ccie/sp/optical_blueprint.html')">http://www.cisco.com/web/learning/le3/ccie/sp/optical_blueprint.html')">http://www.cisco.com/web/learning/le3/ccie/sp/optical_blueprint.html
I have read a book about these things and know them theoretically(am doing PhD )...now I wanna know Cisco Optical products ...any idea about Cisco tutorial ?
and I appreciate your help!!
You're welcome.
You can check out these two books. They should give you quite a bit to think about.
Cisco Self-Study: Building Cisco Metro Optical Networks (METRO) (Warren, Hartmann, ISBN #1587050706)
Optical Network Design and Implementation (Alwayn, ISBN# 1587051052)
And good luck with the PHD!
Mike
