Problem with optical interconnection
lubosbella
we have a Cisco catalyst express 500G switch (WS-CE500G-12TC;IOS:12.2(25)SEG5) with SFP: GLC-SX-MM transceivers. We want to connect a remote building (aproximately 50 meters).
For now, we connecting this two buildings via 2 optical converters with 100Mbit/s speed and then metalic connection to switch.
Now we want to migrate this connection to 1Gbit/s. We want to use a SFP ports so direct connection to switch will be used and converter Alied Telesys AT-MC1004 will be on other side. I painted it on pictures (actual situation-1 and new situation-2). I think all prerequesites are good, but link status is "no link on the port" on cisco switch...
Can someone idea where can be a possible problem or how to diagnostic this problem?
Thanks.
lubosbella
Thanks - no answer is needed. We set it up.
What did you finally determine was the cause of the NO LINK ON PORT on the Cisco Switch?
Problem was that optical convertor is converting 1Gbit/s optic to only 1Gbit/s metalic and we had a PC with 100Mbit/s ethernt card. So when we change ethernet card to 1Gbit/s link was up....
Thanks for posting the solution, rated too . Sometime back someone else have the similar kind of problem.
