Recommendations on Fiber Optic laser safety glasses
romanroma
I was told by a site, due to OSHA - that I will need to provide my own Optical Laser safe glasses. I have no clue what to buy, due to the latter, I am looking for recommendations.
Will be working with Single-Mode fiber and some runs are really long - not sure if that matter due to the strength/power of the lasers.
balaji.bandi
Not sure if this help or not :  ( we use these glasses while we are in the field if we look to check any light on the Fibre (
but single-mode cable, you do not see any light FYI.  , time this is a quick way to look which side light coming and change the polarity of the cable, suggestion always uses a power meter and test it.
https://www.phillips-safety.com/product-category/laser-safety/laser-safety-glasses/shop-by-laser-filters/polycarbonate-filter-lenses/d1500-filter/
BB
Tom Randstrom
I don't have any direct experience with this company or product, but just thought I would share.
https://www.certified-laser-eyewear.com/fiber-optic-telecom-laser-glasses/
