09-19-2018 08:45 AM
I have a ASR 901 series (A901-6CZ-FS-A)
And I wanna know if my baby can support one of this transceivers.
Solved! Go to Solution.
09-19-2018 10:04 AM
Physically they are exactly the same size / form factor.
Internally they are different and the chip inside will report them as different products.
My guess is that since the ASR series is positioned as a WAN router, Cisco doesn't want customers to use transceivers that don't support the WAN PHY in that router series.
09-19-2018 09:40 AM
Just the first one. The ASR 901 series doesn't officially support the S-class 10 Gbps transceivers.
Reference:
09-19-2018 10:00 AM
Yes, I know sir
It doesn't officially support the S-class but I read comments that physically both are the same.
09-19-2018 10:04 AM
