Question is :
you want to setup VPN to New ISP, or just fail over ?
On high level to get concept - If it is just a fail over, you can use IP SLA to track First link if that fails, then route the traffic to Seconds new link.
there many examples around in the configuration example guides.
Let me know any specifically you look so i can point to right direction or document.
