SFP Compatibilty for Catalyst 9200L 24x1G & Stratix 5700
glusic
I need a compatible SFP to connect a Cisco Catalyst 9200L 24x1G switch to a Allen-Bradley Stratix 5700 (BMS06SGL)
The Stratix is made by Cisco, so there should be a Transceiver that will work...fiber is MM and both units have1G speed...Specs show that an compatible SFP for the Stratix is; 1783-SFP1GSX - 1000BASE-SX multi-mode fiber transceiver.
Will that same Transceiver work on the Cisco Switch side???
Right now there's some extra Transceivers on the Cisco switch and I tried to use one in the Stratix, but it didn't work.
Please let me know what is possible in this matter!
Thank You!
George
marce1000
                             >...Will that same Transceiver work on the Cisco Switch side
                        For the 9200L look at : https://tmgmatrix.cisco.com/?npid=1767
  M.
glusic
Thank you:-)
