Swaying latency on a 10G Fibre-Link
michael.busch67
Hi all,
my problem is a swaying latency on the connection between two 4507 switches. On 4507 is an vss-construct the other one is connected two both chassis. At the moment one of the two links is down for troubleshooting purposes.
When I send a ping to the 4507 or some clients sitting behind him I get results from 10 ms to 700 ms. 10 ms to 25 ms are regular.
The Problem occured first after having the switch restarted due to problem with our local power supply.
Changing the supervisorengine or restarting the switch wasn't the solution
Do you have any suggestions where to look to find the root cause?
Best Regards
Michael
0 Replies 0
