Trying to connect 2960-x SFP to 2921 router EHWIC SFP
dlaiakis1
Hi all,
Could anybody help me with this? I have connected the modules (2960 Switch g0/49 & 2921 Router EHWIC g0/1/0) with fiber cable and I have physical link but I don't know how should I proceed with configuration. Is there a way (L2) without applying ip addresses?
I suppose I have to configure the following:
2960-x
int vlan1
ip default gateway
int g0/49 (SFP PORT)
2921
EHWIC SFP PORT int g0/1/0
Thank you all,
Dimitris
7 Replies 7
Philip D'Ath
There is not enough information to answer this question.  What do you actually want this configuration to do?
A simple configuration would involve doing nothing on the 2960, and configuring an IP address on the 2921.
Thank you Phillip for your answer. As you have mentioned I want the simplest configuration for the 2960 to be operational. If I do nothing then when host is connected to switch not working. 2921 is already operational and has Ip configuration. Do I have to configure an IP address on the EHWIC also?
Yes, you need to configure an IP address on the EHWIC port.
I have already configured the built in g0/0 of the 2921. Do I need a different subnet on the EHWIC? Because I get an overlapped IP address message if I do so. Here is my configuration:
2921 g0/0 (management):
interface GigabitEthernet0/0
 ip address 10.10.31.254 255.255.255.0
 duplex auto
 speed auto
EHWIC g0/1/0 (SFP to switch):
interface GigabitEthernet0/1/0
 no ip address
 media-type sfp
Thank you
You sure do.  They are separate layer 3 interfaces.
What does Gig0/0 plug into?  Perhaps you could plug those two devices together?
Perhaps you could use:
 ip address 10.10.30.254 255.255.255.0
Yes this works! If I put this as my EHWIC address and on the switch side for ex. 10.10.30.253 we have connectivity. But the switch cannot reach the outside world as the router does.
Does the Internet connect to this router?  Whatever is doing NAT you will need to extend to include this new subnet.
