Two C9200L-48P-4G Stacking fiber issue
hawkb
Hello community:
     I'm having some problems when stacking two C9200L-48P-4G switch
     The stacking works fine but when fiber module is attached and linked to another C9200L-48P-4G switch,it doesn't work,even won't be recongnized
      Use the same fiber modules to link two separated C9200L-48P-4G works totally fine,so it may not be the fiber module's problem
      Did I messed up something when stacking?
       Thanks,Best Regards!
balaji.bandi
what is the IOS XE code ? can you post  below output
show version
show stack
show module
 show run interface  x/x
show interface x/x
BB
Hi,thanks for reply
       Sorry but the switch may not be reachable now,we accepted an alternative solution
       The configuration I can remeber is that IOS XE version should be 17.3.5,only switchport mode trunk was configured on g1/1/1
If you still looking for some assistance, when you get a chance post the information requested and have access to switch.
BB
