11-15-2012 11:29 AM
Will multi-mode be able to accomplish this or will I need single-mode?
11-15-2012 06:31 PM
OM3 will support 10G to 300 meters.
That said i haven't installed any mmf but OM4 for several years.
Sent from Cisco Technical Support Android App
11-15-2012 06:35 PM
Sorry for the double post.
11-15-2012 07:07 PM
Below is the data sheet for SFP+ transceiver modules. You can reach 220M/660FT on standard OM1 fiber (62.5um) using a 10GB-LRM module. If you are installing new fiber, as was said earlier, an OM3/4 fiber will easily reach your 450FT at 10G.
http://www.cisco.com/en/US/prod/collateral/modules/ps5455/data_sheet_c78-455693.html
If you are installing new multimode, using OM4 will enable you to scale to 100G using the same fiber at those distances (see link below).
http://www.cablinginstall.com/articles/2012/02/commscope-demos-om4.html
11-15-2012 07:41 PM
Cool, looks like I ordered the correct cabling. I had already ordered 450ft of OM3 after reading the documentation earlier today but just wanted to make sure.
Thanks for all of the help.
