04-17-2012 12:16 AM
Hi Guys,
I am faced with the challenge of connecting 2 core switches located at different building about 2 Km distance from to each other. I choose to have on one end, the core switch WS-C3750-24TS-E and the other end with same core switch WS-C3750-24TS-E .
WS-C3750G-24PS-S === WS-C3750-24TS-E
The distance between both building is about 2Km. which Gigabit transceiver module will be the best among the bellow ?
Any thing I should take note as I am implementing this for the first time.Please advise, thanks.
Gigabit Transceiver Modules for WS-C3750-24TS-E :
GLC-SX-MM GLC-T (10/100/1000)
GLC-LH-SM
GLC-ZX-SM
GLC-BX-D
GLC-BX-U
GLC-SX-MMD
GLC-LH-SMD
GLC-ZX-SM
CWDM SFP
SFP-GE-S
SFP-GE-L
SFP-GE-Z
DWDM SFP
DWDM SFP
04-17-2012 05:52 AM
Given the parameters you provided and the information from the Gigabit Ethernet SFP Data Sheet, the solution for you would be the following:
GLC-LH-SMD 1000BASE-LX/LH long-wavelength; with DOM
or
GLC-LH-SM 1000BASE-LX/LH long-wavelength/long haul; without DOM
To reach 2Km, the transceivers require singlemode fiber running between the buildings. The SFP transceivers have "LC" style connectors. Depending upon the optical connector on your backboane fiber plant, you may require a hybrid fiber optic jumper cable (different connectors on each end). These are available from most networking suppliers.
The installation should be straight forward. Make sure the clean the connectors before plugging them into anything. I have some info in the following document on fiber optic cleaning information.
Hope this helps!
04-17-2012 03:14 PM
End-of-Sale and End-of-Life Announcement for the Select Cisco Gigabit Ethernet SFP Modules
Get the one with DOM.
04-17-2012 07:03 PM
In addition to Tom and Leo's excellent advice - end-of-life or not, I always go for the DOM-capable transceivers when I get to specify them. Being able to show the transmit and receive optical power levels from the command line ("show int trans Gix/y det") is priceless.
04-17-2012 07:08 PM
Amen bro.
