X2-10GB-SR v04 DOM not supported ??
We have some X2-10GB-SR v04 that we noticed that the FTLX8541E2-C4 versions include the diagnostic monitoring DOM support. However, the FTLX8541E2-C2 parts do not. I haven't been able to find any part disclaimers showing some of the v04 do not include DOM... All the compatibility docs I've seen state SR support DOM. Am I missing something?
When I enter "show int tran" for the C2 parts there is no output...
The C2 and C4 look entirely the same and are both v04.
Did the X2-10GB-SR not support DOM until C3 or later?
Transceiver vendor name :CISCO-FINISAR
 Part number provided by transceiver vendor       :FTLX8541E2-C2
 Revision level of part number provided by vendor :A
 Vendor serial number           :FNS14111L2X
 Vendor manufacturing date code :2010030801
 Digital Optical Monitoring Capability Byte  :0x0
 Digital Optical Monitoring                  :Not Implemented
 Part number provided by transceiver vendor       :FTLX8541E2-C4
 Vendor serial number           :FNS14270BJB
 Vendor manufacturing date code :2010062801
 Digital Optical Monitoring Capability Byte  :0xC1
 Digital Optical Monitoring                  :Implemented
0 Replies 0
