Does anyone has the GLC-SX-MM transceiver works on a ASR-1002x Gigabit fiber SFP port?I searched Cisco web site and it says ASR1002x supports GLC-SX-MMD only. Just like to see if it actually would work on GLC-SX-MM as well.
I have cisco 4510R-E switch with WS-X4606-X2-E - 10 Gbe cards, i need to connect the Server on 10G Base T ethernet. Also i am using a One-x Convertor module for SFP ( CVR-X2-SFP 10G ) for interlinking a 10G 2960S to this core switch . Can anyone le...
Heiwe have some switches that are connected with our nexus switches via SFP-10GLR. all switches are ok but only one is getting warnings in the logs saying: CET: %SFF8472-5-THRESHOLD_VIOLATION: Te1/1: Rx power high warning; Operating value: -0.9 dBm,...
Hi Guys, My first post.I have a L2 network spanning 12km, 13km, 14km and 16km.Have purchased GLC-LX-SM-RGD and now I notice that the specs say 10km. I am commissioning next week and want to know will the SFP shoot that distance ? Will it help to set ...
I'm trying to select the correct cable to connect to a Cisco Nexus 40G-FET (on a Nexus 6004). I've seen on Cisco's website that says the FET transceiver has 12 fibers in it. Yet when breaking this out to connect to four 10G FETs on a FEX (2232TM-E), ...
Hello everyone,I'm looking for a product to convert SDH to DWDM. Waiting to hear from an expert.Regards,Hesam
Hi all, I see ICMP packet drops between WS-C3750-48P and N77-C7706 via 1G (GLC-SX-MMD). Regards,Mansoor
Hi Experts ,We have replaced exsisting "XENPAK-10GB-LR" with new "XENPAK-10GB-LR+" but when I see show inventory it shows a weird PID.Switch showing incorrect PID :IOS"s3223-ipbase_wan-mz.122-18.SXF2.bin"Switch1#NAME: "Te5/1", DESCR: "10Gbase-LR"PID:...
Hello. Does anyone know if the Cisco ONS 15400 Series supports IPV6? The account where i'm working wants to migrate to IPV6 and this is one of the devices that I coulnd't confirm if it has support or not. Many thanks and regards!
I have 100 Mbps Fiber Optic Broadband Internet Connection using RJ45.No Static IP or leased Line . At present using Dlink normal Router. I plan to change Cisco Router. which model is full my requirement. what is ISR Router ( Integrated Services Rout...
As we know, we cannot configure the optical transmit power of the SFP. Though we can check the receive power level received by peer through the command:show interface transceiver detailHowever, logs have been displaying:Aug 20 06:45:14.434: %SFF8472-...
I have DWDM link which is terminated on POS interface od CRS-1 router.what are the Layer1/Layer2 parameters should be configured on both sides of this circuit
Hi everyoneI have an ME 4624 RGGW ONT which i want to test and connect it directly with a ME3400 Cisco Switch.Is able the router to support this connection (p2p) or is only capable for p2m(GPON) .As i see in its documentation it doesnt mention anywhe...
can someone share information regarding the topic (all cable parameters should pass to a certain SFP module: connector type; mode type; diameter etc)?
Hello, Can you please confirm this part "GLC-SX-MM - GE SFP, LC connector SX transceiver" is enough to connect two Cisco switches WS-C3750X-48PF-S with LC to LC Fiber multimode Optic CableRgrds, Alex
Subject | Author | Posted |
07-25-2024 01:25 PM | ||
05-05-2024 05:19 AM | ||
03-27-2024 12:16 AM | ||
09-10-2023 08:07 AM | ||
08-03-2023 03:20 AM |
