2811 and mgcp in ccm 333
ciscoforum
It seems CCM 333 doesn't support 2811 with MGCP. Can I use the other router ,like 2600 to configure mgcp for 2811 in CCM?
We have a MRP in ics7750 and now want to add one more PRI from 2811 to increase the circuits. The mrp is mgcp so obvisouly we want to use same protocol an put them into a route group.
thisisshanky
Level 11
Level 11
Yes you can use 2600 to run MGCP with 3.3.3. If you upgrade to 3.3.5 i think u will get support for MGCP on the 2811.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
pbarman
Level 5
Level 5
If you are trying to use the 2600 gateway in CCM config for a 2800 router that maynot work, and the gateway will not be able to register with CCM giving you Database Configuration error (bcuz CCM thinks the router is 2600 when in fact it is a 2800). It did happen to one of my customer who misconfigured the router model in CCM.
