7925 connection failed with Extension Mobility
jnepstad
I set up extension mobility on UCM 7.1 and it works find on desk phones but when I try to connect to that service on a 7925 connection fails ????
testeven
Hi!
Can you please check that you are using the latest firmware on the 7925?
What error do you get on the screen? Something like "xml 4 parse error"? If you do, please check CSCsy60203.
Teresa.
Regards, Tere. If you find this post helpful, please rate! :)
shikamarunara
Level 4
Level 4
Were you able to find a solution to this problem?  I am experiencing the same issue myself.
